It is currently Tue Nov 03, 2026 11:17 pm
[ 3 posts ] |
Iboatlkn
Post subject: Sumo Sac 650 Bow Sac Install help! Posted: Sat Mar 19, 2016 2:49 pm |
My boat is 2014 t22
Ordered a wake makers Axis plug and play bag. I was sent a Sumo Sac 650 bow sac. My question is: Do both drain and fill lines go to ports in back/side of bag?
There are 2 drain vents on lower part of sac, one fill port n top, and a port made for sumppump/direct connections port. The Axis factory plug and play has vent/fill/drain 3 hoses. Where do I attach drain and fill? Do they both go on bottom of sac? Vent at top? Seems like bag is made for 2 drains and one fill?
ThatGuy
Post subject: Re: Sumo Sac 650 Bow Sac Install help! Posted: Sat Mar 19, 2016 5:57 pm |
Joined: Thu Jan 08, 2015 6:29 pm Posts: 538 Location: Ohio
If it's the same as mine the full line goes to the port side hole and the drain goes to the starboard side hole. The vent goes on the top center hole. Yes, the fill and drain lines go to the holes on the back of the bag.
_________________ 2015 T22 - SOLD
Iboatlkn
Post subject: Re: Sumo Sac 650 Bow Sac Install help! Posted: Sat Mar 19, 2016 6:13 pm |
Must be, the sumo box said both ports on bottom were drain lines. I guess I just expected a fill line on top of bag, similar to rear sacs. Just wanted to make sure before started cutting hose and hooking up. thanks
[ 3 posts ] |
Users browsing this forum: Google [Bot] and 108 guests |
