It is currently Tue Nov 03, 2026 2:54 pm
 Post subject: Help...
PostPosted: Sat Mar 26, 2016 4:44 pm
2012 Axis A22 -Engine won't turn over at all and the gauges are not coming on. All of my accessories work just fine. Just had it start yesterday. I installed a new component today and now engine won't turn. i assume that I may have blown a fuse somewhere but have checked the fuses I am aware of and can't seem to find a blown one. I don't think its the ECM because there were no sparks or any sign of a large surge. My 80amp protector is not tripped.
Can anyone offer suggestions as to some secrete hidden fuses or have any ideas?
Thank you in advance!!!
Robert
 Post subject: Re: Help...
PostPosted: Sat Mar 26, 2016 5:00 pm
double check to make sure its in not in gear
double check to make sure the safety lanyard cutoff has not been pulled
2013 A20
PostPosted: Sat Mar 26, 2016 5:10 pm
Tried that earlier but to be safe...I just walked out and tried a gain still no go. Its weird that my gauges aren't coming on...
PostPosted: Sat Mar 26, 2016 6:10 pm
Dual battery setup? If so, make sure your on 1&2 vice just a single battery. A connection on your engine battery may have came loose.
I think there is another fuse in the engine bay.
PostPosted: Sat Mar 26, 2016 6:57 pm
engine and batt ground?
PostPosted: Mon Mar 28, 2016 5:07 pm
Does it have a 200amp circuit breaker by the battery switch?
Also make sure it's in neutral
Users browsing this forum: No registered users and 57 guests
