It is currently Wed Mar 18, 2026 10:02 pm
 Post subject: 2016 t22
PostPosted: Sat Mar 26, 2016 7:47 pm
Put a deposit on a t22
Did the test drive today and absolutely loved the boat, only downside was it wouldn't plane with full ballast and wedge down for wakeboarding , going to search the forums as I am sure a different prop can help.
Only down side is once I got back to my dock I realize that I will have to drop the tower every time to raise it up on a lift. ? Not ideal by any means but I will have to deal with it regardless of what I would have bought.
Does anyone know if the cover will go on it with the tower down?
I look forward to becoming an active member!!
 Post subject: Re: 2016 t22
PostPosted: Sat Mar 26, 2016 8:41 pm
I can put the cover on my A20 with the tower down. I wouldn't tow it anywhere like that though. It does snug up but not to the extent of the buffeting it would take on the road.
PostPosted: Sat Mar 26, 2016 9:25 pm
Congrats! What colors/options did you get? Post some pictures when you get it.
PostPosted: Sun Mar 27, 2016 3:20 am
First of all we need to know what is the ballast weight and what prop (don't say the "stock prop"...we need the prop number off the hub) you are using during your demo in order to answer your question. There a handful of "full ballast" options so which bags did you demo (400, 550, 750, 900, 1100)? You haven't given us any specifics so how can we help? The cover with work with tower folded.
PostPosted: Sun Mar 27, 2016 8:41 am
Prop is 15 x 12 2313
P
plug n play ballast - high flow (had 900s in earth ski locker)
Nothing in the bow? Is that normal? I asked for them to throw in the bow bag? 650 as part of the negotiations
For some reason it has the 2015 tower on it even though it's a 2016 boat? Does anyone know if the quick clip disconnects can be installed instead of the knobs? Can see those ending up in the bottom of the lake by the dock?
I'll try and post pictures from my phone (it's yellow and black)
PostPosted: Sun Mar 27, 2016 9:30 am
It needs a bow bag, I have a 650 in mine AND some lead.
The quick connect tower clips is an option on 2016+ boats, if the option isn't selected it is the standard knobs.
PostPosted: Sun Mar 27, 2016 10:32 am
Assuming you had the 350 motor? What elevation are you at?
PostPosted: Sun Mar 27, 2016 11:09 am
Does it have the 2016 dash and windshield changes?
PostPosted: Sun Mar 27, 2016 1:31 pm
How can I tell,
PostPosted: Sun Mar 27, 2016 1:43 pm
Well I can't seem to get the photos to upload through my phone,
So if my tower has the knobs is it impossible to upgrade? I know it seems minor but since I will need to do it every time out it would be a great addition
