It is currently Fri Oct 30, 2026 5:39 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Center Bilge filling with water ....????
PostPosted: Wed Apr 27, 2016 9:41 am
any update with this? i'm having the same issue out of no where..
PostPosted: Thu Apr 28, 2016 5:03 pm
Ok, so I checked this out in the water. I opened the back engine hatch to see if I could find a source of water. I found that when you turn on either the right or left fill switch on the dash, water gush's in from one of the 3 plug and play lines for the bags.
Sounds like a simple fix, is there a plug for this or do you tie two of the lines together? I don't have any bags yet and just want to use the hard tanks. Whats the solution ?
Tow: Ford F-150
Wake: Axis A22
Fly: Piper Arrow
Ski: Yamaha Waverunner & Kawasaki SC ( Sea Couch )
Utility Vehicle : Yamaha Viking
Bike : Harley Davidson FLTSN & Dyna FXD
Dual Sport : Yamaha WR 250R
PostPosted: Thu Apr 28, 2016 6:22 pm
Flip the lever that is directly behind the seat to the closed position. When you open the hatch and your looking where the bags would be the lever is directly under your chin somewhat hidden facing the opposite way on each side
PostPosted: Thu Apr 28, 2016 6:50 pm
OK thanks :D :D :D :D very easy.....
and if I put in bags , I just flip that switch to where it's at now ! correct.
I will drop her in the lake tomorrow , all should be good to go.....
Tow: Ford F-150
Wake: Axis A22
Fly: Piper Arrow
PostPosted: Fri Apr 29, 2016 1:04 am
Easy peezy lemon squeezy. All part of the steep learning curve of your new boat. However, that PnP hose should've been capped off from the factory to prevent the water flowing out.
PostPosted: Fri Apr 29, 2016 11:37 am
I'll see if I can get some type of plugs installed as well so there are no whoops .......likely will order some bags anyway....soon
Thanks for the help......will drop her in the water tonight or tomorrow, attempting to install the Bimini top tonight....it was neglected to be installed as well
Tow: Ford F-150
Wake: Axis A22
Fly: Piper Arrow
PostPosted: Fri Apr 29, 2016 12:15 pm
I literally just threw away those plugs a couple days ago. I would've mailed them to you
PostPosted: Fri Apr 29, 2016 4:10 pm
Thanks AJ ....no worries .....maybe a good excuse to buy a couple of bags...
Tow: Ford F-150
Wake: Axis A22
Fly: Piper Arrow
PostPosted: Sun May 01, 2016 1:17 pm
Ok, so I flipped the levers, all worked fine, except it started filling up when I tried filling the rear tanks , it appears when the hard tanks are full they over flow back through one of the 3 black hoses.
I think you need to have either plugs or a bag installed.....I'll have to buy one or the other.....
Tow: Ford F-150
Wake: Axis A22
Fly: Piper Arrow
PostPosted: Sun May 01, 2016 4:45 pm
I'd buy the bags. What are you planning to use the boat for?
