It is currently Fri Jul 04, 2025 4:02 am
 Post subject: 2016 surf Bimini tight fit
PostPosted: Mon Jun 27, 2016 6:46 pm
With the center zipper zipped and corners on the tower correctly it is impossible to get the support poles in, anyone else have this issue? If I unzip the center and loosen the corners they go in hard(wife can't do it), I'm thinking about shortening the poles slightly. Just curious if this is common.
 Post subject: Re: 2016 surf Bimini tight fit
PostPosted: Mon Jun 27, 2016 7:36 pm
Mine is very stiff as well. Seems to get easier the more you use it.
PostPosted: Mon Jun 27, 2016 8:14 pm
Mine is very tight, also. I can get the support poles in, but it isn't easy. I'm assuming it will loosen over time.
2016 T23
PostPosted: Tue Jun 28, 2016 5:21 am
I was thinking this, but this is about the 10th time it's been out for the day and I don't think it's got any better. Looks like maybe another dealer issue
PostPosted: Tue Jun 28, 2016 5:29 am
Mine is very tight too. I find it's a little easier if I release the corners. I'm think this is a good thing. When it's tight it isn't going to flap and rattle at all. Yeah it's a little tough to get the rods seated but not so much that I can't get them in place.
PostPosted: Tue Jun 28, 2016 6:15 am
Mine was very tight when I first put mine up. Now I leave mine up all the time. I only have about a 1.5 mile trip from my storage to the dock. I did fight with mine the first day we put it up. Like said before, I think we got all the zippers zipped and then had to loosen the corners to get the poles in. Then pulled the corners back.
PostPosted: Tue Jun 28, 2016 7:20 am
do you have to slide the bimini poles in from the bottom or the top? Mine was SUPER tight when I received the boat from the factory. I had to slid the bimini poles into the latches from the bottome. I took the latches off and flipped sides to you now slide in from the top. It is SO easy now. Pull down and lock or unlock.
PostPosted: Tue Jun 28, 2016 7:33 am
YES! From the bottom, I will give that a shot this weekend. Thanks
PostPosted: Tue Jun 28, 2016 8:37 am
That's a really good idea! I'll have to try it.
PostPosted: Tue Jun 28, 2016 8:41 am
Dang, I should have tried that from the top. I fought with the bottom for a while. I am sure the wife would have appreciated that after I knocked her in the back of the head with one! LOL
Users browsing this forum: No registered users and 94 guests
