It is currently Fri Oct 16, 2026 7:57 am
 Post subject: Connecting the radio to the ACC switch
PostPosted: Fri Jul 15, 2016 10:19 am
This information is probably only good for the 2012 - 2015 boats.
This change takes the radio off of the ignition switch and moves it to the ACC switch.
It is simple to do. All you need is 6" of coated wire. It takes about 5 minutes to do and the radio will never cut off when the engine is killed. Also if you use Bluetooth, it won't cause your phone to pause.
If anyone is interested i can post a how-to.
 Post subject: Re: Connecting the radio to the ACC switch
PostPosted: Fri Jul 15, 2016 10:30 am
Also, all this can be accomplished without removing anything. Cut the red wire to the radio, splice it to the 6" wire and use a connector to attach it to the bottom of the ACC switch.
PostPosted: Fri Jul 15, 2016 10:44 am
Probably the best, and cheapest!, mod I've done. Love it.
PostPosted: Fri Jul 15, 2016 3:45 pm
Yep glad I did it as well
PostPosted: Fri Jul 15, 2016 10:17 pm
Please post how to ... I hate having to reconnect Bluetooth all the time. Thanks.
Sent from my SM-G935V using Tapatalk
PostPosted: Sat Jul 16, 2016 5:16 am
his 2nd post tells you how, cut the red wire on the radio harness, add about 6" of wire and crimp a connector on it that will fit tight over the open terminal on the acc. switch. connect it to the switch and your done as power is already at the switch from the factory
PostPosted: Sat Jul 16, 2016 6:50 am
Will this allow you to listen to Bluetooth with out the key in the on position? The only problem I see with this is you could forgot to switch the switch off and you come back to a dead battery.
2014 A24 w/ LS3
PostPosted: Sat Jul 16, 2016 7:30 am
I always just connect mine to the hot side of the battery switch (perko)... that way you do not take up an acc switch.
I separated my interior lights from the underwater lights and used my acc switch.
Wish we had multiple acc switches like my 12 A22 did... :-(
PostPosted: Sat Jul 16, 2016 10:02 am
This is all I used.
PostPosted: Sat Jul 16, 2016 10:38 am
My 2015 is already on the acc switch portion of the ignition key. When you shut off boat just go all the way left with the key and no interruption of anything (even with bluetooth)
Users browsing this forum: No registered users and 72 guests
