It is currently Sat Jul 05, 2025 7:50 am
 Post subject: A24 Tower Height
PostPosted: Fri Aug 19, 2016 12:02 pm
Does anyone know what is the overall height of the tower while on the trailer. I'm renting a dry storage for my new boat during the winter and don't want to drop the tower. They have 10' tall and 12' tall doors. Thanks.
 Post subject: Re: A24 Tower Height
PostPosted: Fri Aug 19, 2016 1:10 pm
My 2014 A24 measures in at 10'4"
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
PostPosted: Fri Aug 19, 2016 1:26 pm
Mi e is right about there as well... I did a 12ft door in my garage.
PostPosted: Fri Aug 19, 2016 2:37 pm
Thanks
PostPosted: Sat Aug 20, 2016 7:30 am
T-23 is about 4" over 10'... raising my roof 4' and putting a 12' door in my garage in about 2 weeks... weeeeeeeee.... lol
PostPosted: Sat Aug 20, 2016 8:04 am
That sounds like fun [emoji4]
PostPosted: Tue Aug 23, 2016 12:04 am
If you don't mind me asking how much would something like that cost? We're looking at buying a house that has a 7' door but 9' ceiling so we're going to raise the door to 8' so I can at least put it in with the tower down.
Thanks
PostPosted: Tue Aug 23, 2016 5:51 am
Thanks
I'm good friends with "Alexander", I believe he just cut the header and raised it 4". Took him I believe about 2-1/2 to 3hrs total by himself. Now he has a detached garage so it's basically cutting the entire garage and jacking it up then filling the gap with a 4ft wall lol. He's a an engineer so he's got this.
PostPosted: Sat Aug 27, 2016 7:34 am
I would need to see the garage BrettLee. It could be easy or complicated. But, there no way you will be able to cut an entire foot out of the existing header to get to 8'. You would need to replace the header with a larger LVL or steel beam. This will require bracing or jacks by someone experienced and a little modification to the existing framing (beefing up the king studs and cripples).
If you just need a few inches, you can do what AJ referenced I did; but your finished elevation on the garage door will probably not look good with the façade of the house... which is fine if you are redneck like me. I just got a piece of white sheet metal molded into a C-channel and that's how I filled the gap. But if you have a brick finish, this will cause problems due to the lintel (brick ledge); it will be in the way.
So.. long story short... no brick and a few inches is probably very cheap. Brick will not be cheap either way (unless you do it yourself). 8' and brick will be expensive.
PostPosted: Tue Aug 30, 2016 8:55 am
I have a 2012 A22 and with tower down have no problems getting into 7' garage door. Just make sure mirror is down.
2012 Vandall, LS3, Wet Sounds, Z5 Cargo Bimini, Rear Lights
Users browsing this forum: Google [Bot] and 80 guests
