It is currently Fri Oct 16, 2026 6:52 pm
 Post subject: Surfgate Inoperative - T22
PostPosted: Sun Feb 26, 2017 9:05 am
The surf gate on my 2014 T22 went through a period of delayed deployment, to intermittently not working to no longer working at all. The indicator flashes as if a gate is opening but it remains closed. The gates will also not open when selecting service mode. Anyone experience similar issues and able to suggest where the problem lies?
 Post subject: Re: Surfgate Inoperative - T22
PostPosted: Sun Feb 26, 2017 9:37 am
Check the fuses on the gates.
PostPosted: Sun Feb 26, 2017 10:16 am
Thanks, I'll check the fuses. Although it seems that would not be the cause of the initial intermittent problem that progressed to the gates being completely inoperative?
PostPosted: Tue Feb 28, 2017 12:23 am
On my A22 the fuse was in a spot where it was always getting water on it and the calcium deposits created havoc. Once I cleaned it and sealed it, my life got better. This fuse was on the port side next to teh transmission kind of almost behind the bulkhead. Poor placement!
PostPosted: Fri Mar 03, 2017 6:12 am
Thanks for the tip. That does seem like it would cause intermittent problems.
PostPosted: Sun Mar 12, 2017 2:08 pm
Sure it could.. and it's free to check.
PostPosted: Sun Mar 19, 2017 10:02 am
Thanks again for the tip. I checked for fuses on the port side of the transmission and do not see anything other than various wire connections and nothing that looks like a traditional fuse. Any chance of forwarding a picture? Thanks
