It is currently Fri Jul 04, 2025 5:56 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Anyone running the ACME 2773 prop?
PostPosted: Tue Feb 28, 2017 12:30 pm
AJWest wrote:
dustinjean wrote:
Elevation plays a big part in the setup as well
Yes sir it does. There have been a handful of "disappointed" Axis owners because they skimped on not getting the 450 engine when boating at altitude
I came across this formula for HP loss at elevation. I'm not sure if its accurate but I've seen it quoted in several places.
HP Loss = (elevation x 0.03 x horsepower @ sea level)/1000
Please feel free to comment as I don't wish to pass on bad info.
2015 T23
PostPosted: Tue Feb 28, 2017 3:39 pm
So 1000' of elevation is 3% loss in HP?
Seems about right. Equates to 30% loss at 10,000'.
Might be a underestimate in the loss. I've always heard about 30% loss at Denver area, ~5000'
PostPosted: Tue Feb 28, 2017 5:54 pm
You are WAY overstating things (even though it might feel like 30%) through the butt dyno.
The 3% rule is just a rule of thumb and obviously isn't linear. You don't keep subtracting 3% from the original number for every 1000'... rather, as you increase, for every 1000', you have 97% of what you had 1000' ago. If you just keep taking 3% from the original number then you'd end up with negative horsepower at 34000', which is obviously wrong given the altitude records for internal combustion aircraft are close to 60,000'.
PostPosted: Sun Apr 02, 2017 6:38 pm
I'm just wondering out of all the people that are having a problem getting on plane with full or nearly full ballast for wakeboarding speed have the FAE on their boat?
2016 A22
PostPosted: Sun Apr 02, 2017 8:21 pm
Do not. Although I noticed a lot of turbulence from someone that has one of theirs shooting up through the wedge access panel, is that normal?
PostPosted: Thu Apr 20, 2017 10:43 am
I have a 2016 T23 w/ 350, running the Acme 2315 prop and looking for the best surf wake. I have 825 pnp in rear and 2 650 pnp in bow.
Should I be switching to the 2773???
2016 T23, 5.7L 350, 3093 Prop/15x12.5 w/ 165 cup, Wake Makers 825lbs PNP rear lockers, Sumo Sac 650lbs PNP, 2nd Ronix Eight.3 650LB bow, Ronix Eight.3 800LB Floor Bag
PostPosted: Thu Apr 20, 2017 12:26 pm
Nick, your prop pitch isn't really going to affect your surf wake shape per se, at least not to a noticeable degree. If anything it will lower your RPM at surf speeds which should help you on gas, but still be enough power to get you to surf speed with ease.
Users browsing this forum: Google [Bot] and 77 guests
