It is currently Sun Oct 18, 2026 9:28 am
 Post subject: Stained Seats
PostPosted: Wed Mar 28, 2012 7:23 pm
I took the cover off the boat today and found stains all over the vinyl. I had it uncovered last week and it was not like this I'm not sure what happened or what to do about it. The stains will not come off I have tried many cleaners and none seam to work is there any chance warranty will cover this.
 Post subject: Re: Stained Seats
PostPosted: Wed Mar 28, 2012 7:33 pm
I could be wrong but that looks like mold. My old boat would do that when i put the cover on and it was wet. 3M makes some mold remover that works fairly well. 2 hours in the sun and it will go away!
PostPosted: Wed Mar 28, 2012 8:01 pm
I hope it goes away it is making me sick.
PostPosted: Wed Mar 28, 2012 8:28 pm
Looks like mildew. I know there are some cleaners out there for it. Bakes has a few listed on there website,
Scott
PostPosted: Wed Mar 28, 2012 9:08 pm
That's not dye stain from the cover...like others have said, looks like a moisture/mold issue.
PostPosted: Wed Mar 28, 2012 9:23 pm
Don't use a mr clean erasure, bleach, or heavy solvent to get it off. Let it sit in HOT sun- Sounds crazy, but I had white vinyl on my old Supra. Dealer left black cover on it during rainstorm outside and when I took it off there were black stains on vinyl. The sun bleached out all of them.
I'd use some Meguires cleaner and then vinyl conditioner. Probably won't take them out, but the sun/heat will fade or erase it...hopefully.
PostPosted: Wed Mar 28, 2012 9:25 pm
i had the same stains on the back on mine as well. When i took the cover off i spewing, i took it out for a ride, it was in the sun for a few hours and completely disappeared.
Same thing happened a few weeks later, hasn't happened since.
Not sure what cause it but i tried a few cleaners and nothing removed it but the good old sun 8-)
Roachy
2011 Axis A20
Sydney - Australia
PostPosted: Wed Mar 28, 2012 9:31 pm
The sun will bleach just about any stain over time. Mildew can be tougher. I know on my Moomba is had to use a Mildew cleaner and the sun. Think I used 303 that was a long time ago though....
Scott
PostPosted: Thu Mar 29, 2012 6:44 am
I had the same issue on my A22 and they are right, take the cover off let it sit in the sun for 30min and it will be gone.
PostPosted: Thu Mar 29, 2012 7:32 am
Simple green if the sun shine thing does not work. The sun always bleached out those spots on my boat.
