It is currently Thu Mar 19, 2026 3:28 pm
 Post subject: First day issues
PostPosted: Sun Apr 30, 2017 7:59 pm
So I had my 09 A22 out for the first time this year and wanted to get a little feedback. It was my first overnight trip, and only my second trip out with this boat - I bought it end of season last year.
1. After only a couple hours out, I came in and parked. I turned the bilge on and it ran for 6 or 7 minutes just steady dumping water. I went out again, 30 minute total ride at dusk to watch the sunset, came back and parked. Left the boat overnight, turned bilge on next morning, same thing - 6 or 7 minutes of water. The boat sat in the water for a couple of hours and I checked again, no water in bilge. Ran for an hour, had 2-3 minutes worth. Is this normal or do I have a leak? PS. Not filling any bags or ballast.
2. There is only one plug, correct? Hopefully not a stupid question. :D
3. The motor seems to have a fairly loud ticking when I throttle wide open. it seems that the throttle at 3/4 to full isn't much different either. My father was in the boat today and said - it sounds just like my car (2009 SRT8 Challenger) did right before the motor went out - slung a rod. I'm not sure if it is normal or if I need to have it looked at. Any thoughts? I'm a bit nervous based on my Pop's comment. FYI I am running a OJ 912 - 14.75 x 15.75 if it matters.
I wish I knew another Axis owner nearby that I could bounce all these questions off of. Thanks in advance for the feedback.
 Post subject: Re: First day issues
PostPosted: Sun Apr 30, 2017 8:29 pm
2009 is same hull as the 2011 I had and mine had 2 drain plugs (center and transom). Could be a loose or cracked hose or loose clamp only leaking when it's pressured with the engine running since you said there was no water after a night of letting it float. Did you fill the ballast when you rode? Could be water from ballast system. Shouldn't be any ticking sounds from the engine at all
PostPosted: Sun Apr 30, 2017 9:21 pm
09 thru 2012 (I think) has a traditional shaft seal that is designed to drip water to cool the prop shaft. If it hasn't been adjusted or repacked, that could be the issue as well.
PostPosted: Sun Apr 30, 2017 9:56 pm
For the ticking, I had it on my LS3. I changed my plugs and it went away. It can also be from gas sitting in the tank for months at a time. Change you plugs and run a few tanks of premium and you'll be fine!.
PostPosted: Mon May 01, 2017 7:25 am
Thanks for the tips. Didn't realize the other plug near/under the V-Drive - will check that.
The shaft seal has not had any attention since I have owned it but I will get it check as well.
Going to order some plugs and get them in ASAP.
Thanks again for the help and feedback.
PostPosted: Mon May 01, 2017 7:40 pm
So there are 2 plugs... Found the second on the driver side near the transmission. It was in so not leaking there. I don't know why I am getting all the water in the boat - my next thought is shaft seal. Will check on the water next time. The more I think and read about the ticking/knocking, the more I believe it to be a spark related. Plugs are ordered and will start there. Updates to follow.
PostPosted: Tue May 02, 2017 7:20 pm
Could be loose plugs or hose clamps from when it got winterized, check all fresh water drain plugs and hose clamps.
PostPosted: Tue May 02, 2017 8:34 pm
Agreed. Will do.
PostPosted: Wed May 03, 2017 4:07 am
Do you have a fake a lake? If so start it on the trailer and see if you can find the source. If running it on water finds nothing it's probably the shaft seal
PostPosted: Wed May 03, 2017 3:12 pm
Ticking at high throttle is often caused by a small exhaust leak where the manifold bolts to the engine heads. Use a mechanic's stethoscope to verify it is not a mechanical sound (or if it is to isolate its approximate location).
The water sure sounds like an engine cooling hose leak.
Wayne
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 53 guests
