It is currently Tue Jul 08, 2025 12:29 am
[ 3 posts ] |
Author |
granddaddy55
Post subject: 2014 surfgate spray, how to eliminate Posted: Sun May 21, 2017 8:25 pm |
Team Axis |
I want to eliminate my 2014 a20 Surfgate spray, to clean up the wave without listing or reducing opposite side sac fill, did Axis come up with a fix it part? I understand they raised the paddles on later models to eliminate it
_________________ 14 A20, 850 rears with kinetic vents, front 950, stock plus wedge and 700 lead P5 53” Ahi, Brigade 4’10” goofy asym, LF Happy pill 4’8”, LF Catalyst Nomad skate, HL wakeboard with old Murry boots
Top |
HalfKiwi
Post subject: Re: 2014 surfgate spray, how to eliminate Posted: Fri Jul 21, 2017 4:18 pm |
Boater |
Joined: Sun Nov 09, 2014 8:53 am Posts: 49 Location: San Diego
I am curious to know if you ever found a solution to this problem. I have the same issue on my A20
Top |
granddaddy55
Post subject: Re: 2014 surfgate spray, how to eliminate Posted: Mon Jul 31, 2017 9:07 pm |
Team Axis |
Yes on goofy side by serious listing with mostly emptying rear opposite locker sac and 3 150's on goofy side of bow, I run 850's rear, 950 front mushroom plus stock and wedge and I plug the vent and drain holes on goofy side rear to keep sac full, I constantly fill front mushroom cause if I plug that it forces water out of the upside down trap vent under dash anyway from pressure of water from bow rise, so I just refill that instead of plug. Be careful how much you fill mushroom bag cause windshield splits apart if to full, so I watch windshield to see it start to separate and then stop, so constantly refilling it due to bow rise water pressure forcing it out of the vent
I can keep both sides relatively clean with no extra bow weight but the wave is short and peaky and it's fun but as the guys on site point out not as much fun as a longer more pushy wave
With regular side I haven't completely eliminated it from wave surface yet but plan to do more listing with even more water weight out of opposite rear sac. The regular wave on the older surfgate models sucks compared to goofy, I got it longer and pushy, just can't get it cleaned up or near as big as the prop rotation goofy side when I extend its length with more bow weight and listing
Top |
[ 3 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 64 guests |
