It is currently Thu Mar 19, 2026 4:46 am
 Post subject: Re: 2016 A24 Flat Wakesurf Wake
PostPosted: Mon Jul 23, 2018 8:15 pm
Ok so sack that thing up to the max
Drop wedge .. the floating wedge works opposite of the power wedge
So you want to make a slight turn into the side the rider is on ...the peak the wake also have the girls stand in the center walk through driver u stand up there as well look for the deepest water run your boat at about like 10.5 mph anything less than 10 Ft deep just hold the rope .... Get on and good consistent then tell the girls to sit on bow and watch it drop along with you wave Then tell the girls to sit on the back and watch the bow ride and wave fall then bring them back to center
PostPosted: Mon Jul 23, 2018 11:17 pm
Same boat as me.. I run 1100s in the rear center filled and horseshoe filler plus 500lbs of lead (100 behind sub, 100 next to batteries, and the rest in under the seats behind driver and the one on port side behind the open seat) wedge is a must when a small crew. I run fast at 11mph plus. Also list the boat a bit to get a lip (especially on regular side)
PostPosted: Mon Jul 23, 2018 11:22 pm
Random photos ImageImageImage
PostPosted: Wed Jul 25, 2018 4:48 pm
How do you like your Red Rocket? I'm riding an inlandsurfer wakesurf board as well. I'm around 250lb so need the volume they provide.
So I took into consideration and experimented with everyone's advice and wanted to thank you for taking the time to share your setups.
Without a doubt the deeper water made a huge difference. For us, we didn't care for much weight in the bow. My best setup ended up being 750s tail, center full, 800lb tube in walkway (centered) and only a few hundred up front, anything more than that hurt our wake. Check it out, let me know what you think.
Sorry for the extra clips this video was made for FB
https://vimeo.com/281710186
PostPosted: Wed Jul 25, 2018 5:53 pm
The red rocket is like surfing on a door lol it's a good board to learn on but I grew out of it very fast. I mainly ride my soulcraft and victoria captain XL now. If u had to have one board it would be the soulcraft hands down.
We are the same way and like the rear heavy... us big bigs need more push but I'm slowly adding weight to the front and adding some length. I just need to drop some weight so I can be small for my board lol
PostPosted: Wed Jul 25, 2018 7:45 pm
Looks like you got it figured out. That regular side looks great.
2013 A22 Black/Orange - SOLD
