It is currently Mon Aug 31, 2026 4:40 am
 Post subject: RV Coolant through Flush Kit?
PostPosted: Fri Oct 26, 2018 8:06 am
Hey Guys,
Has anyone winterized their boat through the transom flush kit using the below device? My boat also has a Sea Strainer if that matters.
https://www.amazon.com/Camco-Winterizer ... +kit&psc=1
I was planning on elevating the tank to use gravity to flow the coolant down to the flush kit. Also will bring up to operating temp so the thermostat opens obviously.
Has anyone done it this method rather than using a Fake a Lake on the water pick up? I just don't see a point doing that when I have a flush kit, but want to make sure it goes through the entire system.
 Post subject: Re: RV Coolant through Flush Kit?
PostPosted: Fri Oct 26, 2018 8:17 am
I have used that kit and a Perko Flush connection for the past 5 years. It is easy to connect water and coolant to the engine. After bringing the engine up to temperature, you switch over to the coolant and winterize the engine. I find it easier than the fake a lake connection that is always leaking on my Axis A24
Jim
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
PostPosted: Fri Oct 26, 2018 12:15 pm
Jim
Where do you have your Perko connected to? I'm guessing I won't need that since I have the factory Flush Kit on my transom. What I don't know is if the factory Flush Kit goes through the engine and transmission or just the engine. That's my main concern.
Side note - I see you're in Atlanta. What lake. I have my boat at Lazy Days.
PostPosted: Fri Oct 26, 2018 1:33 pm
I use one of those. Like you said, use gravity once the engine is up to full temp. One thing though - and it may not apply to you since your transom flush was a factory option - my perko requires a small plastic insert to depress the spring enough to allow a non-pressurized source get to the engine. In my case, if I do not insert the piece, I can get my engine up to temp with hose pressure. Then when I change the valve on the tank you linked nothing happens. No amount of pressure via elevation was enough to get the antifreeze to flow beyond the spring. Took me a minute to realize this.
________
PostPosted: Fri Oct 26, 2018 9:56 pm
Thanks! Yeah I don't think this will be an issue for me. I'll try to use water in the tank instead of RV coolant first to test if it gets through the transom flush kit.
Update - I did talk to a tech and the transom flush kit that came factory does in fact go through the entire engine and v-drive so the perko flush kit wouldn't be needed.
PostPosted: Sat Oct 27, 2018 12:25 am
You might want to engage warm up lever to drive more AF to heater core
PostPosted: Sun Oct 28, 2018 8:06 pm
What does this mean?
________
PostPosted: Tue Oct 30, 2018 7:47 am
Hello Team Axis -- you want to warm up your engine to the normal running temperature (my boat is 161 degrees) before running the Anti-Freeze through the engine, transmission and the boat heater (if you have a heater). You want the thermostat on the engine to engage to let the anti-freeze flow everywhere. I always run the boat heater on high to make sure the anti-freeze also runs through the heater coil as this coil is usually the first thing to break
Jim Fuller
Lake Keowee, SC
2014 Axis A24
PostPosted: Tue Oct 30, 2018 4:33 pm
What happens when your at idle ? Very little flow to heater unless you have a Y joint in your water system which is reason it doesn’t stAy hot. Higher idle using your warm up lever button and the Coolant will go there as well just like when you run the boat in gear at higger rpm than idle
The fan on high doesn’t drive coolant to heater , rpm of motor does
PostPosted: Wed Oct 31, 2018 8:16 am
Ah I see. Up the RPMs. I was just confused with the "warm up lever button". Thanks.
________
