It is currently Mon Jul 07, 2025 7:01 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: problem starting
PostPosted: Sat Jun 09, 2012 5:38 pm
Ya I'm over at his place right now, fuel pressure is steady at 55, and it gets injector pulse and spark signal very quick, it takes about 3 to 5 seconds to fire off, to me most of the time it starts normal but then when you least expect it, 6-7 seconds to fire, it's intermittent, 1 out of 10 times it will take longer, we would know more but it got hot so we took it out for a ride hehehe
PostPosted: Sat Jun 09, 2012 5:44 pm
It kind of acts like mine did when the tach was acting goofy but the service light doesn't pop up, next time I come out I'm going to bring my tach and swap it in and see what happens, this is a really cool boat, he's done so much little stuff to this thing, it's really personalized!!!
Custom airbrushing and embroidering on the seats, and the stereo in this thing will almost shake you out of the boat!!
PostPosted: Fri Jul 06, 2012 8:47 am
Bump ...... ever switch tachs?
 Post subject: problem starting
PostPosted: Tue Jul 10, 2012 10:55 am
I have the same issues as above... But get a service alarm. The alarm quickly goes away and the boat runs fine. I run regular 87 with no more that 10% ethanal as stated in inmar's manual. Would switching to ethanol free help? I can't imagine so. Just a thought?
PostPosted: Tue Jul 10, 2012 6:16 pm
Have you swapped the rotor and cap? If you start and stop your boat often, it can suck in moisture into your distributor cap and cause arcing. Normally this will result in rough running as well though.
PostPosted: Wed Jul 11, 2012 10:41 am
most of us have had the problem since day 1, new outta the box
PostPosted: Tue Apr 23, 2013 2:24 pm
BUMP walter did you ever switch tachs and retest?
PostPosted: Tue Apr 23, 2013 3:11 pm
Not yet, his lake dried up and he removed his boat, it has filled back up but he took the boat to storage, I don't think he put it back in the water yet.
PostPosted: Wed Apr 24, 2013 10:05 am
WOW is that normal for that lake? .... let me know if you ever switch tacks
PostPosted: Wed Apr 24, 2013 10:56 am
Ha no it's not normal, they haven't had any rain in quite a while but it got hit with some not to long ago, this drought sucks
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 80 guests
