It is currently Thu Jul 02, 2026 1:43 am
 Post subject: Deck track
PostPosted: Sun Oct 14, 2012 4:33 pm
Anyone could give me guidance on how to install the deck track. In fact i couldnt find the right pieces for the sidelines next to the tower.
Much appreciated for any feedback
 Post subject: Re: Deck track
PostPosted: Sun Oct 14, 2012 7:48 pm
Not sure about gel coat prep, I imagine you do not want any dirt or polish on your gel coat. But one piece of advice, put each piece on a barrel or bucket out in direct sunlight for a few hours before install. This will hopefully give them a new "memory", convex, and should help prevent the corners from peeling up. Definately make sure they are flat in the sun before install, at the very least.
PostPosted: Mon Oct 15, 2012 3:33 pm
I installed mine myself after purchase last summer. I wiped the area down with rubbing alcohol and then applied. Pretty easy job. I had a couple left over that I couldn't find where they went and they ended up going under the sundeck at transom.
PostPosted: Mon Nov 26, 2012 8:58 pm
How long has every one had there deck track for? I'm thinking about putting it on my rig but wondering how it will look in 10 years be all scabby and wrecked? I have never seen it so I wouldn't know? Can any one fill me in?
PostPosted: Tue Nov 27, 2012 4:58 pm
I don't know about 10 years, but the worst I could see happening after a few years is the corners might start to peel up. I wouldn't buy another boat without it.
PostPosted: Tue Nov 27, 2012 11:25 pm
nasty, x2
PostPosted: Wed Nov 28, 2012 6:35 am
Yea some of mine already peeled up after the first season.
PostPosted: Mon Dec 03, 2012 11:42 pm
I have a couple of corners peeling as well. Anyone have advice what to use to glue it back down? Would crazy glue be a bad idea?
PostPosted: Fri Dec 07, 2012 6:19 am
Is it really that good?
PostPosted: Fri Dec 07, 2012 11:18 am
It is if you've ever slipped and busted your hind side on the gel coat before!
