It is currently Tue Nov 04, 2025 8:56 pm
 Post subject: Added AUX USB port
PostPosted: Tue Feb 12, 2013 6:28 pm
I got this AUX USB port from amazon made by SeaWorthy. Installed in the same place as the 12v plug is on drivers side hardest part was running the cords to the radio.
 Post subject: Re: Added AUX USB port
PostPosted: Tue Feb 12, 2013 7:31 pm
Does it work with the radio? I tried to put on a USB extension cable on mine and run it under the seat and in the glove compartment and it wouldn't read with the extension cable hooked up.... That's when I went with a Bluetooth
PostPosted: Tue Feb 12, 2013 8:51 pm
@walter how did you do the Bluetooth option on yours?
PostPosted: Wed Feb 13, 2013 3:50 am
Walter I am having the same problem with my radio too I have the alpine 9886m and there is a USB plug behind radio and it want read my iphone and I read manual it said it will only work with iPod 2 3 4 5 Generation I don't have one of those but my friends do so hopefully it will work but the Aux works great.
PostPosted: Wed Feb 13, 2013 3:55 am
To get Bluetooth to work you have to buy $120 Transceiver that hooks to back to radio
PostPosted: Wed Feb 13, 2013 7:53 am
My Sony HU reads my iPhone if I plug the phone cord directly into the USB cord on the radio, it just doesn't work with the extension for some reason. I picked up a clarion hands free blue tooth for around 50$ It hooks up to the aux RCA inputs on the radio, it works really good but doesn't allow use of the pause or other functions on the radio, pretty much have to use the receiver to skip songs, taking calls works good and it's easy to hook up, bad thing is I think it's discontinued, every website I found it on says its out of stock and clarion doesn't list it on their online catalog any more.
http://www.sonicelectronix.com/item_965 ... LT370.html
PostPosted: Wed Feb 13, 2013 8:37 am
How long of extension did you use Walter ? When using a USB extension over 10ft you buy usb with a Signal booster IOGEAR GUE2118 USB 2.0 Booster Extension Cable (Black)
Iogear
$37.95 $28.59 that's on Amazon
PostPosted: Wed Feb 13, 2013 9:54 am
I can't remember, it was either 8 or 12 foot
PostPosted: Mon Feb 18, 2013 4:56 pm
That makes sense then because you have to add the length of the cord on the radio and the length of the iPhone cord.
http://en.m.wikipedia.org/wiki/Universa ... #section_5
That's talking about ideal situations. So if the iPhone is a bit slow to respond or if the cable itself is not perfect, not well shielded, etc... then the real world max will be much less than the spec'd 5 meters.
