It is currently Sat Jul 05, 2025 12:20 am
 Post subject: 2012 Plug N Play
PostPosted: Fri Mar 08, 2013 7:30 pm
OK gang I have a problem and need assistance.
Need some info to help straighten this out.
When I purchased my 2012 A22 it had a line item on the bill of sale for Plug N Play.
Boat is at the dealer having stuff done and Ballast bags was one of the items on my list. Got a call today from service guy saying that my 2012 didnt have the PNP in the rear. He said that PNP was not offered on the rear until 2013 and everythng before that was an add on. Is this correct?
He also said that the front PNP was standard on the 2012. Is this correct?
I had a line item on the Bill of Sale for PNP and was wondering if front PNP was actually standard like he said. I dont want them coming back and saying that the charge was for the front and that if I wanted rear that it will cost more. I am just trying to get all the facts before the owner calles me back. I am a little discouraged because when I orginally ask about adding bags I was told that it had PNP and all I had to do was to add them.
Service guy is finding out from Axis what all the boat was supposed to have on it when it shipped. Probably was an error on their part or on the dealers part for putting the line item on there. Think it was around a $400 charge for PNP.
I am still very early in this process and just wanted input so I could have my facts straight about what is standard and what is an add on and about how much it cost. I really hope this was an oversight and they get it straightened out.
How much does it cost to add PNP to the rear? Worst case scenario is this something that I could add myself?
Thanks gang and I will keep everyone posted.
 Post subject: Re: 2012 Plug N Play
PostPosted: Fri Mar 08, 2013 11:07 pm
I have 2012 A22 also with PNP. The front is the only one with it own indendent pump for filling and draining. The rear PNP actually you phsyically hook up to the factory hard tanks to fill and drain using those pumps. How ever it takes longer to fill the rears with setup. I just use tsunami pumps my fatsacs and them while the factory tanks are filling.
PostPosted: Fri Mar 08, 2013 11:30 pm
That service tech doesn't know what he is talking about. If you had PnP on your bill of sale, you should have had the plumbing in both the front and each rear locker. Only the front gets its own pump, the rear bags will piggy back on top on the rear hard tanks and use the same switches/pumps. It's been the same way since 2009 when Axis started. Sounds like this guy just doesn't know how to change around the plumbing in the back. Point him to the long how-to thread on here. By the way, I also have a 2012.
PostPosted: Sat Mar 09, 2013 3:49 pm
Quick question....
There is nothing to plug into in the back. Will they have to cut out a hole in the floor and pipe it into the hard tank. Have seen newer boats at the shows with a tube coming out of the floor. I dont have this.
Thx
Users browsing this forum: Google [Bot] and 67 guests
