It is currently Sun Jul 06, 2025 8:14 am
 Post subject: Axis A22 - Cruise Control Issues
PostPosted: Sun Apr 28, 2013 7:33 am
Hey guys,
Yesterday I was on the lake and my cruise seems to intermittently stick on. I tried to unplug the battery for a few seconds to see if it will reset and it doesn't. Sometimes it unlocks, but often it stays lock at a certain speed which become a little annoying when you are set to 10Mph. See here: http://youtu.be/WeuEri_ZyK8
Anyone can help? It there some sort of lock function that I'm not aware of?
Thank you,
Mike
 Post subject: Re: Axis A22 - Cruise Control Issues
PostPosted: Sun Apr 28, 2013 11:30 am
Does your boat have a depth finder? If so scroll the info panel to something other than depth and see how that works.
PostPosted: Mon Apr 29, 2013 8:06 am
Hi Walter,
Yes, the original depth finder was installed on the boat. I will give that a shot and see if it fixes the issue.
Thank you,
Mike
PostPosted: Mon Apr 29, 2013 10:41 am
Have you tried turning off before you start the engine?
PostPosted: Mon Apr 29, 2013 10:45 am
Hi PatatoShack,
That's the main issue is that I cannot turn off or change the speed. Yes I have tried, but no it does not work as it acts like if it was locked ON with a certain SET speed.
Mike
PostPosted: Thu May 02, 2013 8:38 am
This is an old issue with the tach. Axis swapped most of these out with a new version under warenty.
If you turn the boat off with the display on depth, the next time you run the boat cruise will be locked up. Reset the display to anything other than depth and shut off the engine until the displays go out, restart and all better.
PostPosted: Thu May 02, 2013 8:53 am
Wow great to know... Thanks Morrisdl!
PostPosted: Thu May 02, 2013 9:50 am
What year is yours? I would bet 09 or 10. Well out of warranty by now, but still worth emailing Axis about a replacement tach. I have found them to be very good the couple times I worked with them. Sometimes the dealers get in the way of good support, so be persistent. Good luck!
PostPosted: Thu May 02, 2013 9:55 am
Yeah - 2010 A22 :(
I could try emailing them. Do they require the serial number of the boat or what do they need?
Mike
